Just about got all my disc upgrade kit installed I've run into a problem lineing up the brass banjo end there is a bolt that goes through it with a hole in it for feeding fluid to the caliper I marked the bolt so I can see when it appears to be lined up with the hole in the banjo fitting, then when I attempt to bleed them it squirts out fluid. Ive tried several times with brass washers with no luck. Any suggestions or techniques would be much appreciated
Did you use the brass washers on either side of the banjio fitting ?? If not, get new ones and place one washer on either side of the banjio. Val
