BRAKES !
Discussion in '1955-1959' started by cosmo1957, Nov 2, 2005.
  1. cosmo1957
    cosmo1957 Member
    Cambridge Canada
    Can i get a 6 bolt disc brake conversion kit that will alow me to change to 5 bolt discs later, without too much additional cost ?
    I'd like to do the upgraded brake deal now on the front and maybe change rear end later to 5 bolt and have the option to do front 5 bolt later as well.
    I wanna run disc/drum setup as a minimum.....
  2. backntyme55
    backntyme55 Member
    tulsa
    I AM LOOKING AT THE KITS SOLD BY CPP AND PERFORMANCE ONLINE. HAS ANYONE USED JIM MEYERS IFS? HE TOLD ME IT WOULD BE CLOSE TO STOCK HEIGHT WHEN IT WAS INSTALLED USING ITS HIGHEST ADJUSTABLE SETTING? BUT I REALLY DONT WANT TO LOWER MY TRUCK AND I WISH I KNEW SOMEONE THAT INSTALLED IT ON THEIR'S. ALSO I AM LOOKING FOR THE BEST POWER BRAKE SET UP FOR UNDER THE FLOOR TOO.I GUESS I LEAN TOWARD DIRECT FIT BRAKES UNIT BECAUSE IT HAS A DUAL DIAPHRAGM AND MASTER.ANY THOUGHTS?
  3. chevymantrucks
    chevymantrucks Member
    Lincoln U.S.A
    I used no limit and they are the best bang for your buck in my book.Look on EBay as they to have alot of parts for 55-59 Chevy and Gmc trucks...Good luck...Chevyman
