burnout
Discussion in '1973-1987' started by 76454, Jul 30, 2003.
  1. 76454
    76454 Member
    seattle
    I was just wondering how you do a burnout with an automatic. I used to do the power brake move(stomp on brake and gas together), but it burned up the ring and pinion. Any suggestions?
  2. Zeitgeist57
    Zeitgeist57 Member
    Naples
    Ring and pinion? As in the differential in the rear? I wouldn't think that would be related to doing an auto-tranny burnout.
    BTW...as far as I know you use the brakes to do a burnout...otherwise you could use a line lock on the front brake lines to hold them in place as you floor the gas :7
  3. muddman15
    muddman15 Member
    Moore USA
    In my 81' I can just stomp the gas and it'll burn 'em until i let off without any brakes
  4. 84inArk
    84inArk Guest
    In my 84' I can just stomp the gas and it'll burn 'em until i let off without any brakes
    Well 4 starters it helps w/ a more powerfull motor...........
    what do you have 305?
  5. scotty101
    scotty101 Member
    Southwest mn
    correct me if i am wrong but i know one older cars the parking brake or the emergancy brake locked the front wheels i am not sure if the same is true in these trucks but you could just lock the front wheels with that
  6. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    Well If you do not have big HP trying to do burn out with out the line loc. will be hard, in most cases if your brakes are ajusted to the best set up.
    Attation: not the best way but will help, reajuust your rear brakes a little losser just to help put a little more breaking to the front. How ever you should be careful because this will make the front lock up sooner to the rear breakes in a pinic stop so you should know how it will feel be good at foot pressure & be able handle it. The safer way would be the line loc.
    Or just take a pray bottle of water spray the rear tires a few times.:D
    Oh and doing this on the street can get you a ticket.:(
