By-pass oil filter question
Discussion in '1947-1954' started by omega7979, Jul 8, 2009.
  1. omega7979
    omega7979 Member
    chicopee Massachusetts
    I was thinking about the bypass oil filter and wondering if the oil drains back into the crankcase to the oil pan after its been filtered ?? if thats the case wouldnt it lower the oil pressure of the oiling system as a leak would ?? hopefully someone can clear this up for me......
    thanks
    Leon
    Not a problem , it doesn't change the oil pressure nor flow one bit .
    it does help your engine by filtering out some of the crud that naturally accu,ulates in the oil . no matter what some guys who don't understand will try to make you think .
