C-10 to C-20 front suspension swap
Discussion in '1960-1966' started by kevinstone, Jun 4, 2012.
  1. kevinstone
    kevinstone Member
    Sarasota, FL
    Does anyone know if the upper control arm brackets that are bolted to the frame need to be changed if doing a C-10 to C-20 front suspension swap.
    I know the upper control arm studs are a larger diameter for the C-20, but I am not sure if the C-10 bracket can be drilled or if it needs to be changed.
  2. kevinstone
    kevinstone Member
    Sarasota, FL
    Wanted upper control arm brackets '64 C-20
    Does anyone have or know of anyone that has the right and left upper control arm brackets that will work on my '64 C-20?
