cab change
Discussion in 'General Chevy & GMC Pickups Talk' started by mortition, Apr 29, 2003.
  1. mortition
    mortition Member
    Can I put a 2wd cab on a 4wd truck 87 chevy 4x4?
  2. Butch60stp
    Butch60stp Member
    Birmingham United States Of America
    Provided its the same style cab ....yes.
    Butch
  3. mortition
    mortition Member
    it is the same style cab. it came off the same year truck just
    that it is a 2wd. but it seems like the 2 back acb mounts are not matching up within the same depth range as the 4 front ones.
    mortition
  4. tech1
    tech1 Member
    The cabs will be the same but the mounts on the frame are different from 2WD to 4WD.
  5. mortition
    mortition Member
    what will i have to do to make the cab match up to the mounts
    on the 4wd. which ones will i have to change? just the back two?
  6. 84_chevrolet
    84_chevrolet Member
    In the cab change the 4wd cabs have a larger hump in the middle for the transfercase. I put a 84 model cab on an 77 frame and you have to have a 2 inch body lift and the back mounts are different just build a 1 and a 1/2 inch more spacer and everything lines up fine.
    Hope that helps you.:D :D
