Cab Mounts
Discussion in '1960-1966' started by John, Feb 3, 2003.
  1. John
    John Member
    I am looking for new cab mounts for my 66 3/4 ton, all of the sites I have looked at only carry mounts for the 1/2 ton. I would like to go poly but at this point rubber would be great.
    Thanks for any help
  2. Glen
    Glen Member
    Tulsa
    John,
    I had the same problem on my '63 3/4 ton. I had to build a bracket and weld it to the frame mounted part of the cab mount, and then use 1/2 mounts. Just grind all the rubber off the metal base and fabricate one. You can probably look at someone's 1/2 ton, take a few measurements, and get some idea of what you need to make. Good luck.
