cam break in
Discussion in 'General Chevy & GMC Pickups Talk' started by 74X4Burb, Feb 17, 2005.
  1. 74X4Burb
    74X4Burb Member
    Fort Shaw U.S.A
    I am going to put an edelbrock #2102 camshaft in one of my 350s and was wondering how to break it in. I,ve looked at some websites but I would like to know what some of you have done.Karl
    '71 3/4 ton 2wd camper special,soon to have '76 350.
    ________
    Video review
  2. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    MAKE SURE TIMING IS SET, AND EVERYTHING IS HOOKED UP CORRECTLY. MAKE SURE AT NO TIME WHEN THE ENGINE IS RUNNING THAT YOU LET IT LUG OR IDLE. AFTER YOU START THE MOTOR SET YOUR IDLE SCREW AT ABOUT 3000 RPM'S AND LET IT RUN FOR A GOOD 15-20 MINUTES. WHAT YOUR DOING IS POLISHING THE CAM WITH THE LIFTERS. AFTER YOUR DONE CAN DROP IT BACK DOWN TO IDLE AND PERFECT YOUR TIMING AND IDLE SETTING. FOR THE NEXT 500MILES OR SO DRIVE IT AT DIFFERENT RPM'S LIKE ON A HIGHWAY TO INSURE ALL SEATING AND FINAL BREAKING IN. CHANGE YOUR OIL AND CRUZ.
    66 KUSTOM
  3. 74X4Burb
    74X4Burb Member
    Fort Shaw U.S.A
