Cam Installation
Discussion in '1947-1954' started by oldtruckluvr, Mar 6, 2006.
  1. oldtruckluvr
    oldtruckluvr Member
    Pekin USA
    I have a 1954 chevy truck with a 235 in it. I am going to be putting in a new cam. I was wondering what the easiest way to install the cam would be? Is it possible to leave the engine mounted in the truck and replace the cam or should i pull the engine and do it? Also what is the easiest procedure on replacing the cam? I am doing this for the first time and do not want to screw something up. Any help would be great, Thanks!!!
    I don't want fuzzy memory to give you bad advice but you've got to remove the oil pump & distributor as the gear runs off it and there's a retainer plate with two big screws in it , be gantle in removing it so the lobs don't gouge the cam bearings .
    New lifters with new cam of course and never , _EVER_ use re-ground cams nor lifters ! .
    Get some good cam paste and use it liberally on the lobes & lifters , follow the manufacturer's breakin instructions _exactly_ the speed and time are critical to ' work harden ' the lobes & lifters for long service life ~ donlt start the engine and screw around letting it warm up , the instant it fires you need to run it up to the spcified RPM's and HOLD IT right there for the specified time period .
    Get a factory shop manual ($20.00) as it's all in there , in detail .
    -Nate
  3. 51papy
    51papy Member
    Osawatomie KS
    Nate
    Where can you find new solid lifters. I have had no luck. CD ##### and my FLAPS all say they might be able to get them out of the discontinued warehouse. They tell me that there are two or three in the US. AND @ $40.00 PER lifter. That's a little steep for my budget. Going back with a 1955 235 with 261 cam.
    51 Papy
    Mike
    RE: Cam Followers (Lifters)
    Kanter's maybe ? I know someone over on the StoveBolt Page said they're still in production....
    YOU all know more about Internet searches better than I , I always aks you all for help in finding stuff , I'm just an old mechanic .
    -Nate
  5. lazys53
    lazys53 Member
    live in Sparks,NV, but my heart is in Cali.( I wil
    Hey Mike--51papy--Go to www.patricksantiquecars.com . Patricks got alot of rebuild/upgrading parts. --lazy
  6. 51papy
    51papy Member
    Osawatomie KS
    Called Patricks today. Thanks for the info.
    51 Papy
    Mike
