Can anyone help me?
sniperf150
I'm thinking of purchasing a old chevy truck, the owner says its a 62' chevy, but i don't think so.
It has dual headlights, it has Apache 20 emblems on the side,its a flatbed, it has a 235ci I-6 with a 4 speed transmission. If this isn't enough of a description, please tell me what I need to do to find out what year this is.
Any help is greatly appreciated.
please email me at [email protected]
Thank You.
1960- In 1960, Chevrolet introduced this new body style truck. It was a completely redesigned truck from the previous years, both in appearance and functionality. Front suspension is a newly designed torsion bar system. Rear suspension is a coil spring and trailing arm design. The low mounted grill consists of 2 horizontal bars connecting dual headlamps. CHEVROLET is embossed across lower bar. Center opening of grill has 3 louver insert. Front of hood has oval openings on each side. Parklamps fit in center of vertically louvered bezels and fit in these hood openings. Windshield is a wrap around design. Front windshield pillars slope forward. Vent windows are wider at tip than bottom. The dashboard consists of two large arches on either side. Instrument cluster is housed in left arch. The right arch houses the glove compartment. Master cylinder is a dual cylinder. One side operates brakes. The other side controls a hydraulically operated clutch. Small back window is standard with big back window optional. Front bumper vertical bolt holes are 3 1/4" apart. Custom cab trucks have aluminum trim strip from front fender to rear of bed on fleetside models. Side emblem consists of CHEVROLET on top with the word APACHE and series designation below.
1961- Very similar to 1960 truck. Lower bar of grill is now smooth. Plated grill insert is similar to 1960 but also has four vertical louvers and the letters CHEVROLET. Parklamps now have winged design bezels on either side of lens. Side emblems consist of the word APACHE and the series designation only.
1962- Similar to previous years but with the following changes. New modern hood without oval openings as in previous years. Character line around body is now continued around sides and front of hood. Parklamp lens is mounted in similar location surrounded by aluminum bezel. Turnsignals are now standard equipment. Grill is similar except center oval has 9 rectangular openings made from 2 vertical and 2 horizontal bars. Lower bar again has CHEVROLET embossed. Single headlamps are now used surrounded by large ribbed bezels. Custom cab trucks trim extended from front fender to rear of bed on fleetside models. A second strip of trim branched off of door trim and extended to rear of bed. Side emblems consist of a red bowtie and the series designation on top of a vertically ribbed background.
1963- Similar in appearance to earlier years. Front suspension now uses variable rate coil springs. Clutch uses mechanical linkage. Grill has CHEVROLET embossed in lower bar and single headlamps surrounded by smaller round bezels. Center of grill consists of 56 rectangular holes formed by 3 horizontal and 13 vertical bars. Front bumper vertical bolt holes are now 4 3/4" apart. First year for the 230 ci. and 292 ci. engines. Side emblem is a vertical rectangle with series designation on upper portion and red bowtie below.
1964- Redesigned cab. Windshield is now flatter design than before. Windshield pillar posts slope back. Vent windows are wider at bottom than at top. Redesigned grill consists of numerous vertical and horizontal cross hatches for a screened look. Upper grill bar has CHEVROLET embossed. Single headlamps are surrounded by rectangular bezels. The dash is now full cab width and has a lip along entire top edge that forms a shelf to reduce glare. First year for self-adjusting brakes. Factory in dash air conditioning optional. Emblems are a square with series designation embossed and bowtie on top.
1965- Similar to 1964 trucks. Side emblems are now rectangular shaped with bowtie in left portion and series designation in right portion.
1966- Similar to 1964 and 1965 trucks. First year for the optional 327 V8 engine and Turbo-hydramatic transmission. Side emblems are rectangular shaped with bowtie on top and series designation on bottom.
Rick
[email protected]
Looks like the owner was off by a year (or two). Any particular reason you're looking for this year model.
My personal preference is the 64-66. Not only do you not have to put up with the knee knocker cab but the later models have self adjusting brakes and a more modern interior. Parts tend to be a tad easier to find too (in my area - ATL).
