Capillary Tube Temp Gauge Possible Electric Mod for 54 Truck
Discussion in '1947-1954' started by Dean Taunton, Jan 25, 2020.
  1. Dean Taunton
    Dean Taunton Member
    Anyone aware if someone has tried to replace the mechanical gauge with electric gauge insides using the same gauge face? Thinking about trying it using a 56/57 electric temp gauge and sender or even a newer one that may fit and can be mounted to the original 54 truck temp gauge face.
    If you can find the gauge from a Chevy / GMC 'Dubble Duti' P-Van it'll fit your original gauge cluster and if you find a 1955 ~ 1964 one, it'll be 12 volts stock....
    Good luck hunting, if Bill or others help you find the correct part # it should be dirt cheap N.O.S. on The Bay Of E .
