Carb Q
Discussion in '1960-1966' started by cowboy, Dec 28, 2003.
  1. cowboy
    cowboy Member
    What does a 2GC 2barrel rochester carb flow in cfm?
    Thanks I got a buddy who is trying to put together a tri power setup.
    Cowboy
  2. bob1965
    bob1965 Member
    Wake Forest USA
    Try vintagespeed.com They have just about everything.
  3. Frankc
    Frankc Member
    Raleigh USA
    there is a lot more to setting up trips then just the CFM of a carb. Befor I can offer you any help I will need to know more about what you are doing. What eng. 350, 383 etc.? is it stock? If not what cam? So-on so-on so-on.
    Frank C;)
  4. cowboy
    cowboy Member
    the Engine is 283 with a 350hp 327 cam duration @.050 is 222 for both intake and exhaust, and lift is .447 for both intake and exhaust. The pistion compression is some where between 11-12. the intake is from offenhauser(sp?). it will have a 5 speed manual trans behind it, too. Well so he says. I was just trying to figure out the total cfm for and engine mock up on desktop dyno. thanks for the help to both of you.
    Cowboy
