carb spacer
Discussion in '1955-1959' started by achansen22, Jun 13, 2013.
  1. achansen22
    achansen22 Member
    I have a 5/8" spacer between carb and manifold. Is this necessary and what is the advantage , if any?
    thanks, andy
  2. steve
    steve Member
    Virginia
    Spacer
    Andy,
    I do believe it acts like a insulator, keeping the carburetor cooler and the fuel from evaporating prematurely. This is accomplish as it isolates heat transfer form the intake and exhaust assembly.
    My three cents. :eek:
  3. achansen22
    achansen22 Member
    makes sense...thanks
    Carby Insulator
    I assme we're talking about a 235 here ?
    It's *very* imporant .
    Once in a while the original ones will suddenly develop cracks , not to wory , just buy a new one and remember : NO GASKET between the insulator and the intake manifold , only between the insulator and the carby .
  5. achansen22
    achansen22 Member
    now you tell me!..I just picked up the other gasket yhis morning...thanks anyway.
    andy
  6. vwnate1
    Carby Gasketing
    No worries , just hang it on a nail in the shop , you'll be needing it sooner or later .
    FWIW , always try to use the very thinnest gasket you can , this will prevent leaks , weeps & seeps from developing later on .
    In Carbys ' thick gaskets cause vacuum leaks .
    Of course , the Rochester 'B' series carby you have , needs those four slots cut in the base gasket to provide vacuum for the power valve .
