carburetor for '64 230 motor
Discussion in '1960-1966' started by kuseyd, Oct 30, 2002.
  1. kuseyd
    kuseyd Member
    My '64 C-10 has a Rochester Model B carburetor. The truck gets terrible mileage (10 mpg), the plugs are sooty with 1000 miles on the newly rebuilt motor. I've talked to some carb experts that are split on what to do: one says convert to a MonoJet, the other suggest that the rebuilt carb has the wrong jets and that the only solution is carefully rebuild the carb, and experiment with smaller jets. Any suggestions?
  2. JustaTruck
    JustaTruck Member
    Elizabethtown, KY
    Hi,
    I've got a '65 230, manual choke. Ten years ago the owner had the carburetor replaced with a Rochester Monojet. It caused me some confusion at first when I went to rebuild it. The carb seems to work fine, except that after 10 years the gaskets don't seal and it floods continuously. Time to rebuild.
    I want to know if anyone else has an opinion on the best caruretor for a 230. Stick woth the Model B, the Monojet, or something else?
  3. kuseyd
    kuseyd Member
    Thanks for the information. I beginning to think it's best to just stick with the Rochester model B, and try to figure out why it runs so well, yet I get terrible gas mileage and the spark plugs are sooty after 1000 miles.
  4. Arizona64
    Arizona64 Member
    Sierra Vista US
    Don't have a direct answer for your question, but I have a good link. Go to http://www.inliners.org. You'll find tons of information for you inline engine. Check out my site at http://www.geocities.com/chevyportal for even more classic truck links!
    Good luck!
    Regards,
    Arizona64
    Regards,
    Arizona64
