Changing Gear Ratios
Discussion in '1955-1959' started by 58fleetside, Sep 15, 2008.
  1. 58fleetside
    58fleetside Member
    Boulder, CO
    I have a 58 with the 4 speed transmission. What would be the best (easy/inexpensive) way to get a higher gear ration so I can drive this thing on the highway at a lower RPM? Are new gear sets available for the transmission?
  2. NDtruck
    NDtruck Member
    Valley City United States
    Depends
    What is the truck used for? Just a joy rider? You could always swap out gears in the rear end instead.
    I think Classic parts has a set of 3.38 gears which would be more highway appropriate than the 3.91 or 4.10 gears you've likely got now, no?
    just my 2 cents.
  3. ccharr
    If you have a 3/4 or a 1 ton then you may have 514's in the rear, if that be the case, 410's is most likely all you can get without special building a system for your truck. If you have a 1/2 ton then call Patric's and see of he can set you up. Mine is a 1ton that had 514s and not has 410s. If you live near So. Cal., call Hoopers rear end exchange in Sun Valley, Ca.
    Hope this helps,
  4. 58fleetside
    58fleetside Member
    Boulder, CO
    This is a 1/2 ton truck for fun. I have a new GMC that I use for actual work. How do I contact Patric's?
  5. ccharr
    gears
    http://www.patricksantiquecars.com/ ,Also if you were to ask the host of this site, they could also get you the 388's . Truckshop also has them, I was there today and seen them in their catalogs.
    Hope some of this helps.
  6. ccharr
  7. jon0249
    jon0249 Member
    Dallas, Texas USA
