Changing Gears
Discussion in '1960-1966' started by MikeRS17, Aug 22, 2002.
  1. MikeRS17
    MikeRS17 Member
    Hey there, my 1960 rear end is finally discovered after hours of scrubbing off 42 years of grease and grime. The code on there is MA, I looked in my assembley manual and found that that rear end is the 3.90(no positraction) rear end used through 63 in the C10. I have a 3 spd tranny and a 350 chevy small block. Will I be able to go high way speeds in this or not? If not can I just replace the ring and pinion with lower gear ratio or higher not sure on that one. Please any help would be appreciated.
  2. dvalentine
    Good News- Yes, you can get to highway speeds..
    Bad News- Your motor woll be doing about 3200 RPMs to get there.
    I'm not sure on how high a ratio is available for that rear. I would try to get higher than 3:70 for freeway cruising without taching the RPM range above 2500.
