Clean Frame
Discussion in '1955-1959' started by fast56chevy, Oct 27, 2005.
  1. fast56chevy
    fast56chevy Member
    Hey I was wandering how to clean my truck frame. Theres a lot of dirt and some rust. Would a power washer work? Any help would do. Thanks
  2. cosmo1957
    cosmo1957 Member
    Cambridge Canada
    Whatever it takes is my suggestion !!
    Powerwash all the loose crap as much as you can get.
    I used angle grinder and hand drill with wire wheel brushes of various types.
    If you can afford to blast it thats not a bad idea either......
    Good luck
  3. cosmo1957
    cosmo1957 Member
    Cambridge Canada
    I tried to post pic, but it doesn't seem to work ?
    Help ......!
  4. fast56chevy
    fast56chevy Member
    Thanks for the help. If you could get those pictures that would be great.
  5. backntyme55
    backntyme55 Member
    tulsa
    I AM DOING THE SAME PROJECT SO FAR I HAVE USED 1" TO 4" PAINT SCRAPERS TO GET THE HEAVY DIRT OFF. THEN A WIRE WHEEL BRUSH ON A DRILL AND HAVE EVEN SAND BLASTED SOME OUT IN THE DRIVE WAY. I TRYED A BELT SANDER LAST AND IT CUT PRETTY FAST WITH 60 GRIT ON IT. I ALSO HAVE A SEAT IN THIS TRUCK THAT I DONT PLAN TO REUSE IN TULSA.I HAVENT DONE ANYTHING BUT PUT A SEAT COVER ON IT BUT ITS NOT IN BAD SHAPE.
  6. houtxengr
    houtxengr Member
    Magnolia USA
    I sprayed my frame with a fine mist of diesel & solvent...letting it soak for ~1 hour. Then I attacked it with a 2500 psi pressure sprayer. Finally, I sandblasted the entire frame.
    Time invested = 4 hours.
    Primer & paint frame. Time invested = 2 hours.
    Looks like brand new...
    I'm told that you can do the first two steps, letting it dry for a day or two. Then coat it with POR-15 or Eastwood "Rust Encapsulator" (looks like bed liner stuff). Everyone says this is the easiest method to coat & seal your frame. I just didn't like this look...
    I can send pictures if necessary (mrhoutxengr@sbcglobal.net)
  7. dunhamfield
    dunhamfield Member
    Crosby Texas
    I am a big fan of Powder Coating.
    I took my bare frame to have it powder coated. It was really rusty and nasty with grease and tar. They sandblasted, preped and powder coated for $350.00. I couldnt believe how good it came back. The powder coating sealed and got to places that you could not get paint. The way I figure, I saved money. So I took the rest of all my undercarriage parts to them as well....Terry
  8. chevymantrucks
    chevymantrucks Member
    Lincoln U.S.A
    Get some gunk and a wire brush and go to town.Let it sit for a few hours the power wash it.Works for me every time i restore a truck......Chevyman
