clip question
Discussion in '1955-1959' started by scarab777, Nov 7, 2006.
  1. scarab777
    scarab777 Member
    meridian, id
    hey guys,
    I was about to purchase a superride and found a frame shop with a Nova clipped frame he wants to sell. anyone know how the nova clip rides in a '55 3100? the guy says it's true and ready to go. any help on this would be great!
    boise steve
  2. 57 restomod
    57 restomod Member
    If I understand you correctly it's a Nova clipped 55 frame that's ready to go? What ride height is it set up for because depending on how it was set up it can ride high, low or in between. You also want to make sure the rad support mounts are there and in the proper place. If done correctly the Nova clip is okay. A good start for a budget wise conversion.
  3. scarab777
    scarab777 Member
    meridian, id
    clip
    Well, I went with the Martz hub to hub and should see it in a couple of weeks. I did a lot of research and seems that with the quality and the adjustments (without cutting anything) it was the best solution. Thanks again for your inputs. Steve
