Hi... Does anyone know how many ft-lbs the six bolts on the clutch cover should be torqued to? A picture is attached. As best I can tell in the shop manual, it is 11 ft-lbs but that just doesn't seem enough to me. Thanks!
11lbs is definitly incorrect, crank those babies tight! I don't know the torque required but you don't want those bolts coming loose... Im gonna bet its closer to 100lbs but I don't know for certain, I typically just crank em tight and don't look back. haven't had any issues yet.
http://www.portlandbolt.com/technicalinformation/bolt-torque-chart.html Check out this link it has all the torque specs for all the different size bolts......Big Tim
