Connect the hoses for a seperat oil filter
Discussion in '1947-1954' started by wokri, Dec 7, 2019.
  1. wokri
    wokri Member
    Germany
  2. fab51
    fab51 Member
    Central Missouri
    Wolfgang-
    I am assuming that you are using the original accessory AC canister type oil filter, or something similar. The upper inlet of the canister will be connected to the hole on the right, which is the same location that the oil pressure gauge is connected. You will need to use a tee fitting in order to connect both at the same time. The bottom outlet of the filter canister will be connected to the hole to the left.
