Continue S10 swap
Discussion in '1947-1954' started by coilover, Jun 7, 2017.
  1. coilover
    Frame cleaned
    All S10 brackets cut off, ground, and AD Engineering mounts on with SCREWS (welded later). Note 2 inch tall spacer on rear mount to fit cab cross member
    Thin spacer on front cab mount. Kit uses stock S10 mount cushions.
    Bed cross members with mounts. Front mount is a square long tube and all bot to the SIDES of the S10 frame.
    Bed mount access hole in factory rear cross member so bolts don't run through bed wood.
