I have replaced the bushings on the Mustang II control arms in the past, using donor parts. I removed teh old ones - pretty easy, just remove the nuts/bolts and 'knock' them out (I used a hammer and a socket). I ordered a new set/kit from Speedway Motors but since I had to knock out the old ones, I did not try to pound the new ones in. I took the arms with the new busings to a machine shop and they pressed them in. I think if you used some oil one the metal parts, you might be able to pound the new ones in or press them in with a coupld of c-clamps.
