Hi Bruce ;
The deal is this : when the engine was new , and _IF_ it wasn't a
Monday or Friday build and the machinist wasn't drunk , etc. etc. ,
GM said you'd set the cylinder to TDC and adjust to _zero_ lash then
tighten the ball nut 1 - 1/2 turns more (that works out to 540°)
but , in real life that's almost always WAY too much , so , set each
valve to TDC and adjust the rockers to zero lash then start the
engine and warm it up , it'll prolly click a fair bit , use a socket
on a flex handle not a ratchet and slowly and gently tighten each
valve only enough to where the clicking noise stops .
If you cannot tell any clicking stopping , loosen it up until you
hear it click then tighten it and move on to the next valve in line .
If the engine slows down or begins to miss , you've tightened that
valve too much , loosen it up until it clicks then try again .
Of course this must not be done until you've set the dwell to 33°
(points gap tp .016") timing dead nuts to either 10° BTDC @ idle or
32° BTDC all in .
-Nate
Bruce Asked :
Hi Guys, Please tell me the amount of clearance on valve lifters
for a 59
Chevy six with hydraulic lifters. Seems to be some mis-information
in the
books. Thanks, Bruce
32° BTDC all in .
-Nate
Bruce Asked :
for a 59
in the
