I have a 1966 chevy c10 pickup and i need a tech sheet or data sheet stating the original specs on the motor rear end and such. i have already tried cliffordperformace.com and there download thingy was full of giberish and i couldn't read it enough to make sense. i was wondering if some of u guys have needed this info in customisation b4 or not or know where to find it . thanx ahead of time for ur cooperation and patience.
Charles F Rising JR if the truck has the factory seat look on the back of the seat. You have to get access to the springs of the seat there is a build sheet that is put in all cars and trucks at the factory. It tells you what to put in the vehicle when it is being built, and it should give you specs on some of if not all the parts of the truck or car. that should help a litle.
Charles F Rising JR I forgot to tell you, if it is not on the back cusshion then check under the seat also. it is by the springs as well
