Deameter Ball of the oil pump
Discussion in '1947-1954' started by wokri, Aug 21, 2010.
  1. wokri
    wokri Member
    Germany
    Hello,
    I have ask one threat ago that I had have problems with the oil pressure cause the ball in the relief valve was missing. I had put another ball in the oil pump with a diameter of 10mm.
    My question is, does anybody know how tall is the ball in the oil pump for 235 cui engine?
    My second question is, is there a special order to pull the screws of the manifold?
    Ask
    Wolfgang
    Manifold Fasteners
    Removing them ,no worries .
    Re-installing is very important ! tighten from the center and work outwards , going back and forth...
    Remember : at each end is a stud , NOT a fastener ! if there's nuts or bolts used on the first or last , the exhaust manifold WILL break .
    Someone will prolly come along shortly and explain this better than I have .
  3. Bobby 57
    Bobby 57 Member
    Long Beach Ca
    I was told that no bolts were used on the ends was so the metal could expand,since the manifold is a two piece assembly. It may or may not be true but thats what i was told 30 some tears ago.
    Bobby
    Correct !
    And the ' tears ' part comes after some DIY'er puts bolts in the ends when they install a spiffy cherry dual outlet exhaust manifold and it cracks into two pieces..... :eek: .
    I've seen quite a few thus .
