DECODING MY TRUCK
Discussion in '1955-1959' started by MY 57 CHEVY, May 23, 2004.
  1. MY 57 CHEVY
    MY 57 CHEVY Guest
    Hello I have a 57 chevy 3100 series p/u. I have a few questions about my truck. I tried your decoding and the results were 1957 3100 series plant Kansas City, MO . The vin on the truck is 3A57K121850 . Engine block id numbers casting # 3837004 . Stamped id number F3I8H just left of distributor. Head casting # 3836848 no stamped number on head. Trans has 3 casting numbers tail housing #3707196 side plate #3845157 and trans housing # 3845122 Need to know if this is the motor that came in the truck new. Want to know if I have a matching number truck. Also my paint & trim codes do not match Info I have found. Paint code is 766 & trim code is STD. These codes are on the id plate front drivers inner door jam. The truck is blue in color now. And the old paint looks to be blue also. The codes in the glove box are gone. What color do I paint motor ? Need info on what color to paint all parts of the truck . Like motor ,bell housing, trans, linkage and etc. Thank you for your time.
  2. MY 57 CHEVY
    MY 57 CHEVY Guest
    FOUND PAINT CODE 766 IS ALPINE BLUE 11640. IF ANY ONE CAN HELP W/ OTHER IT WOULD BE A LOT HELP.LIKE TRIM CODE (STD)NEED HELP W/ IT AND OTHER. SEE ABOVE .THANKS BRANDON
  3. 4JSAToo
    4JSAToo Member
    Tucson
    Check out the first conference in this forum [General Chevy & GMC Pickups] The post [Info on history of truck] Could be steering you in the right direction. At least you found the color code listing: I couldn't on the lists for your year that I have. Good luck with a fun investigation....
    Bob:)
  4. MY 57 CHEVY
    MY 57 CHEVY Guest
    Thanks Bob:7
  5. MY 57 CHEVY
    MY 57 CHEVY Guest
    I have found a book called Catlog of Chevy Truck ID Numbers 1947-1972. It can help alot. Brandon:7
  6. Rustyoldtruck
    Rustyoldtruck Member
    Is this a 6 cyl engine?
    If so what is the cast number above the starter motor? it is a letter followed by 3 or 4 digits. It is half way between the oil pan flange and the pushrod cover.
  7. MY 57 CHEVY
    MY 57 CHEVY Guest
    RUSTY OLD TRUCK LOOK AT MY FIRST POSTED AT THE TOP . ALL INFO IS THERE . THANKS BRANDON:D
  8. Rustyoldtruck
    there should be a cast number a little farther left of the distributor it is the date code. not stamped but cast.
  9. MY 57 CHEVY
    MY 57 CHEVY Guest
    OK THE CASTING NUMBERS FOUND ARE (CON 4 ) & (C127) ALONG W/ STAMPED NUMBER ( F3I8H ) IS THE I A (1) ONE ? LIKE TO KNOW MORE ABOUT THE CASTING NUMBERS . IS THE MOTOR CASTING BIRTH 1st MONTH 27th DAY ? THANKS BRANDON
  10. Rustyoldtruck
    Thats the number I needed... C127 was cast march 12 1957, correct for your truck. You can also check the vin number on the frame to see if it matches your cab vin, it is stamped on top of the frame at the rear edge of the upper fromt shock mount on the drivers side.
    For color check out www.cheverolettruckservice.com click on engines...1957 I believe the pic at the bottom is the correct color.
    Good luck, Terry
  11. Rustyoldtruck
    Sorry...www.chevrolettruckservice.com
  12. MY 57 CHEVY
    MY 57 CHEVY Guest
    THANKS TERRY. YOU HAVE BEEN A BIG HELP ALONG W/ BOB. THANKS GUYS.:7 BRANDON
  13. suburban hunter
    suburban hunter Member
    [updated:LAST EDITED ON Jan-13-05 AT 00:18 AM (CST)]Just read your post , I myself just bought a 57 3100 big window with the same color codes 766 with a 235 3 on the tree. I would be interested in your findings. I just got the truck from Ak, I have another one on the way from WY for parts it has a a 4sp on the floor. I have not even be able to go through the car i received yet. Any info will help save time.
    big window made in St Louis
    http://iserver.chevyduty.com/dcforum/User_files/41e60bca0800dd78.jpg
    enginehttp://iserver.chevyduty.com/dcforum/User_files/41e60bf206000bf1.jpg
    Just starting with the restoration. have you used any of the kits from chevy duty on their catolog?
    both are the same cowl codes
    engine on big window
    http://iserver.chevyduty.com/dcforum/User_files/41e60da90800e8a8.jpg
    engine on parts car
    http://iserver.chevyduty.com/dcforum/User_files/41e6111808bc467b.jpg
    parts truck made on KS
    http://iserver.chevyduty.com/dcforum/User_files/41e61160089c47f9.jpg
    I look fowrd to complete a restoration by spring.:)
  14. Larry Bear
    Larry Bear Member
    Check this site out...
    http://www.chevrolettruckservice.com/literature/1957/colors-truck/index.html
    Larry
    56 Stepside - Daily driver
    Ferns Country Store
    Carlisle, MA
  15. suburban hunter
  16. suburban hunter
    that color code can be seen better at
    autocolorlibrary.com under 1957 chevy trucks has all colors for that year
    jay
