Deve Krehbiel solution PCV valve solution.
Discussion in '1947-1954' started by Blueflame236, Apr 28, 2012.
  1. Blueflame236
    Blueflame236 Member
    Norway
  2. Flashlight
    Flashlight Member
    That looks clean and neat..I read his posts way back when i first started my resto.
    PCV Location
    This , IMO ;
    Is the very worst possible location for the PCV Valve as it is directly in the oil mist and so will tend to suck out a fair bit of oil , always a bad thing .
    There's a reason the factory never did this simple thing .
  4. fab51
    fab51 Member
    Central Missouri
    I pondered this set-up for a while. Besides the oil mist like Nate says, who has the tools around to drill a 1" hole in a 1-1/4" freeze plug? Not this guy...
  5. Blueflame236
    Blueflame236 Member
    Norway
    Sounds reasonable
    It sounds resonable what Nate says here! I`ll go for the valve cap /intake solution and combine it with the Apmco container wich also needs vacume.
  6. vwnate1
    " Ampco Container "
    ?? Eh ?? What ?? .
    I know I'm tired but what did I miss here .
    Of course , now that I mailed your new cap off , Sunday I found one with the correct 6 cylinder PCV Valve still in it , I left it behind for the next needy old Trucker .
  7. Blueflame236
    Blueflame236 Member
    Norway
    Ampco lubricator
    The Ampco lubricator needs vacume and is to be connected to the intake manifold aswell as the hose from the PCV valve cap right ?
  8. Bill Hanlon
    Morris Ranch TX
    Like this Nate: http://ampcolubes.com/home
  9. vwnate1
    Top Cylinder Oilers
    Thanx ! .
    I remember these , they actually do work as advertised .
