Apache, I did the power disc conversion on my 1950 3100. It is doable if you have some mechanical skills. The brake lines do need to be modified, there are write ups on how to do it. I used straight brake lines that you can buy at Napa auto parts, and cut and bent as needed. A couple of problems I ran into was that the caliper brackets didnt work well with the steering stops, the speedo cable is a very tight bend around the booster with my stock tranny, and some of the mounting holes didnt quite line up when mounting the booster setup. Also I would recommend the remote mounted reservior setup for ease of access to brake fluid. I had to add a pressure activated brake light switch due to some other changes I made, and there is also a low pressure warning light sensor you should probably hook up. Overall I am pretty happy with the setup, and it stops like crazy. I went to a different wheel setup, but the wheels I had seemed to clear the calipers with no modifications, although I have heard that spacers may be needed. I would definitely advise the upgrade if you are to drive it daily in traffic. Hope this helps.....Mike
