disc brakes
norton
Feb 3, 2013
i want to put disc brakes on a 1963 chevy truck c20 does anyone know of parts off of newer trucks that would work this is a 3/4 ton
Any `73 to 87 C 10, grab everything, booster, master, prop valve, spindles, caliphers, brackets, hubs. you may have to buy new rotors, so as to stay with the 6 lug pattern, they make standard rotors in 1 inch and heavy duty rotors in 1 1/4, so note which rotors you get from the donor vehicle.
this is a 3/4 ton does the same rule apply and what about the rears bieng its a floating axel
Same as I'm doing only your doing a 3/4 ton. 2wd right? If so its the same as im doing. 73-87 c20 and up to 89 sububan 3/4 ton. Square bodys.
