Distributor Question
Discussion in '1955-1959' started by MY 57 CHEVY, Dec 10, 2004.
  1. MY 57 CHEVY
    MY 57 CHEVY Guest
    I have 1957 chevy 3100 w/ 235 6 cly. Is there a gasket for the Distributor? When I pulled the distributor there was no O ring or gasket. I check a spare motor I had and the same, no gasket or O ring. The parts house looked it up and sold me a O ring but it bigger than the shaft on the distributor but small enough to fit under the vacuum advance . It done not look like it would help keep oil from coming out and dirt coming in.If anyone can help. Thanks for the help. Brandon bradshaw.
  2. cosmo1957
    cosmo1957 Member
    Cambridge Canada
    I wouldnt think you'll get too much oil up there to worry about it, but you can make a gasket easy to solve your concern, Using cardboard or cork or ? no big deal to seal the deal !:)
  3. ljw
    ljw Member
    tucson
    I am fairly certain that there is a papaer gasket that was used,and any supply house should have them as it would be the same up into the 1980's.
    RE: Distributor Gasket
    Originally there was a flat fiber gasket , as the dizzy must be free to rotate for the vacuum advance to work correctly , it's a snug , not tight fit into the engine block .
    Any big truck shop or hydraulic shop will have fat o-rings , get one that fits not overly tightly .
    -Nate
  5. MY 57 CHEVY
    MY 57 CHEVY Guest
    Thanks Nate. Brandon:D
