Dome light
Discussion in '1947-1954' started by Larrys 48, Dec 29, 2009.
  1. Larrys 48
    Larrys 48 Member
    Spokane, WA
    Anyone know if the on/off switch on the dome light can handle 12v? I was planning on just changing out the bulb...
  2. Bill Hanlon
    Morris Ranch TX
    Shouldn't be a problem. An engineer would have to try real hard to design a socket, wiring and the dome light contacts on the light switch to work on 6 volt and not work on 12.
  3. ol' chebby
    WOrks fine, as do all the sockets. All you need is bulbs, a runtz on the fuel guage and an IC64 coil from NAPA.
  4. Larrys 48
    Larrys 48 Member
    Spokane, WA
    Remember engineers got us to the moon and back
    Thanks Russ and Bill. That's what I thought, but I smoked :eek: my original one - the togle was stuck and I freed it with WD40...either the WD or the damaged switch caused me some real panic as the blue smoke started. I have another replacement from eBay to install.
  5. vwnate1
    It's prolly fine now , that was just you burning the WD-40 (AKA useless crap)
    off after it made a dirict short to ground.....
    I made my dome light up out of several old $2.00 swap meet ones .
    FWIW : ANY 6 volt switch will easily carry 12 volts as 6 volts uses more amperes than 12 volts does .
