Door alignment
Discussion in '1947-1954' started by Guest5979, Jul 11, 2015.
  1. Guest5979
    Guest5979 Guest
    I set my cab back on the frame not lined up or bolted down just noticed the driver door hit in the middle when I open it up I drilled a hole and put a screw in each door bracket so door would line up when put back on.
    Is it possible the cab not mounted to the frame it's bound up.
    Thanks Robert
    Door Fitment ' fun ' (or not)
    Yes Robert ;
    Wait'll the body is firmly attached to the chassis before shimming and adjusting the doors .
  3. Guest5979
    Guest5979 Guest
    Doors
    That was one of the first thing I did was line up the door gaps put pilot holes with screws in hinges I opened door today to get a wrench noticed rubbing on the cowl so I won't freak out on another issue I have many already
