Door Glass
Discussion in '1947-1954' started by SkeeterBilt, Jan 5, 2014.
  1. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    There is a thread on the HAMB in the AD thread about the metal framed that go around the 47-51 door glass. but not much has been said. i too will be replacing my door glass. since i work in the glass indusrty ill just get some glass cut and want to know if i can re-use the frame.
    Early Door Glass
    Yes you can .
    However , there's a " Barrel Nut " holding the bottom of the frame on and it's tricky to get loose and back on again .
    My local Glass Shop had no difficulty with it , I sure did .
  3. ol' chebby
    I reused the frames on the 50 I built. Clean them up good and give em a good coat of epoxy paint and they'll shine for the life of the truck.
  4. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    done. ill be doin all my glass at work real soon. ill take pictures
