Door hold open springs
Discussion in '1947-1954' started by Larrys 48, Feb 11, 2008.
  1. Larrys 48
    Larrys 48 Member
    Spokane, WA
    Any of you messed with these springs? I can't figure out how/where to install them in the hinge. A picture would be worth a thousand words. :confused: Larry
  2. azcarman411
    azcarman411 Member
    Rimrock, Az
    Got one picture before my battery went dead, one tab of the spring goes in one part of the hinge and the other tab goes in the other part of the hinge. Chris
  3. ol' chebby
    they are an extreme pain in the arse. One end of the spring fits in the top of the hinge pocket, the other in a hole in the top of the hinge. getting them in is one thing, getting them to stay is another...
    There's A Conspiracy , Folks......
    And it revolves around Detroit's inability to make decent door check springs , this seems to affect all brands and years :cool: .
    Anyways , the easiest thing to do is buy a large cheap screwdriver and file a notch near the tip to facilitate installing the spring .
    It's a PIA and when mine broke I just threw the stubs away .
  5. 52wasp
    52wasp Member
    Wilton, New Hampshire
  6. vwnate1
    Neat Link !
    Thanx ! :)
  7. Larrys 48
    Larrys 48 Member
    Spokane, WA
    Thanks
    Great thorough info on door hinges. Thanks.
  8. LOUDEMRILK64
    LOUDEMRILK64 Member
    TERRE HAUTE
    I say the easiest way, is go on ebay and get another one. About $15
  9. f4fantm2
    f4fantm2 Member
    Kentucky
    I put new pins and bushings in my hinges, and had no problem getting the springs in as I put the hinges back together. The pins and bushings are pretty inexpensive, and if yours are worn at all, this might be the best time to rebuild the whole hinge. Might save time and effort in the long run. Just a thought.....
  10. Ruger338
    Ruger338 Member
