driveshaft
Discussion in '1973-1987' started by mattpadl, Jul 16, 2011.
  1. mattpadl
    mattpadl Member
    I have a 1986 c10 long box with a 2 piece driveshaft and hanger bearing 70" long.
    I have a 1986 suberban for parts with a one piece driveshaft that is 68.5" long.
    Can or should I loose the hanger bearing and 2 piece driveshaft that is in need of all new universals, and use one piece driveshaft .
    would it work?:confused:
    would it be better with no hanger bearing?
  2. Roadhazardguy
    Roadhazardguy Member
    Canyon Lake Texas
    No they have different wheelbases as you can see from the lengths, it might work but a two piece drive shaft is better anyway. If you have a vice it is a pretty simple job to replace the u joints, just make sure to get the higher quality ones and greasable too. Check out your carrier bearing while your at it because the rubber is usually bad by now.
