Drop spindles
Discussion in '1973-1987' started by banjo, Aug 11, 2002.
  1. banjo
    banjo Member
    by the bay usa
    several years ago i cut 3/4 of a turn off the front springs and got about 3 1/2 inch drop. and with special drop shocks it drove ok not like a new caddy but ok. now i am thinking i want a better ride. i have looked at a couple different spindles but need some input and advice. also i would like to get as much positive caster as i can get.
    talk to me whats best
    81 chev short bed stepside dropped 3.5 front 5 rear small block 400 richmond super T10 ford 9 inch auburn locker.
  2. SM
    SM Member
    I really don't believe in cutting springs. Springs are designed by professionals and don't hold up to the same ratings when cut. A new pair of shorter springs with the same rating is the best bet.
    Check out a good BellTech kit. that's what's on mine, 4" all around..
  3. mrlurch13
    mrlurch13 Member
    Tampa USA
    Charles F Rising JR i would go with ethier belltech or mabey eibach they have kits for that type of set-up they should be comparable in price also.:D
  4. mrlurch13
    mrlurch13 Member
    Tampa USA
    Charles F Rising JR you also might want to try FATJACKS spindles they make what you want for your truck
