Economy disc brakes
Discussion in '1947-1954' started by coilover, May 2, 2009.
  1. coilover
    This is a company that will make disc brakes for anything no matter how off beat and at 1/2 the price of others. They start with brackets for under $100 and let you gather the parts from salvage yards or parts stores (they furnish a list) right up to complete disc conversion kits which are around $350 turn key. This is half price or less and the parts are of very good quality. They are now making rotors that fit onto the factory brake drum hub so there is no bearing fit problems. You may have to grind off some bumps, like rivet heads or wheel mount guide pins, but they give instructions for that also. In some cases the hub lug bolt flange has to be turned down some on a lathe but this is a very simple machine operation which should not cost much. I told Zig I'd dig through my paper work to find the name since it is unusual. http://www.scarebird.com/
  2. Zig
    Thanks, evan!!!
    You the MAN! I certainly appreciate the info! I can't wait to have a little more time to check into this! I guess things happen for a reason. I'm glad I haven't rushed any decisions. This sounds like the ticket to my "6-lug-keep-the-original-wheel" problem!
    Thanks, Evan!:cool:
    Evan
    Have you used this outfit to upgrade a Huck equipped AD to front discs ? .
    What caliper did you use ? .
    Dual MC ? .
    TIA ,
  4. coilover
    Nate, I talked with them and do not have them for an AD but his good friend does and I hope at around the same price. His name is "Chuck" and phone# is 425-398-1634 and hours are 10-6 Pacific time. Let us know the details if you contact him.
  5. vwnate1
    Thanx !
    I'm about to leave the State to go see Moms but I'll try to give them a ring when I return .
