Edelbrock carb
jonesda123
Feb 24, 2009
21
Which edelbrock carb is the right one for a 305 ? Everyday driver here I think its the 1406 but don't know alot about switching carbs out do I have to buy and coversion kits ,brackets, Its got the factory 4 barrel Quadajet on it but the 4 barrel is screwed up Wanting to upgrade a little .
The quadrajet is what's known as a "spreadbore" carb, meaning it has small primaries and large secondaries. The intake manifold is made with this same spreadbore pattern to match up. The 1406 is not a spreadbore and will not work unless you change the intake manifold.
Go with a 600 cfm. With the carb you might need to get an adapter to make it work with your manifold or do the upgrade to a performer intake.
:D....I agree with "drabo" I used this same carb on my 305 ;
and yes you will need the adaptor unless you change out the intake and if you do change out the intake go with the edlebrock. I think you will like the improvement. :D
What wrong with your carb? If it just needs a rebuild get a kit. I really do not like other carb like "CARTER" (Edelbrock carb) I would get a Holley If your going to change the carb different brand. As said the factory carb and Intake are spreadbore . Edelbrock makes Great Intakes manifolds it would be set up for both set up's of 600 would be best or 650 if you can get a 600.
which one do i need to make the change ??
edelbrock # 2692
OR
Edelbrock #2696
edelbrock # 2692
OR
Edelbrock #2696
can't remember but, best way to tell is check bolt hole and measure for clearence......I think I used the #2692 have to find the paper work but, I'm sure either one will work.
