H
Huck
Guest
Hello, I am working on an all stock '64 Chevy short bed step side. It has been my daily driver, then it gets worked on weekends. Until I had a weird problem. I was not starting well, and ended up needing a jump a few times. I was busy and didn't have time to work on it, so it sat for a month. When I went to restart it (with new battery and alternator) it wouldn't run for more than a few seconds. It seemed like the same amount of time as the gas I poured in the carb. So, I replaced the fuel pump, cleaned the filters, and checked the tank. All ok. But then, a 2nd problem.
My Starter went dead. I bridged the starter siloniod (after I put a new one in) and it would turn over, but not at the switch? I checked the switch and the light said it was good. So then I went wire by wire looking anything wrong. Nothing. But when I hooked it all back up the switch worked... ...Once. Now I'm right back to wear I started.
Any ideas? I hate the idea of tearing out the wiring again, and not knowing that it will do anything.
