Would anyone mind posting a pic of the Emergency brake set-up from the cabin side and the underside setup also. I only have a Shop Manual for a 47' and they still had Floor lever. My 53' has a 62' open shaft rearend. I have gotten everything restored up to the pedal from the rear. I must be missing some pieces because I can't figure out how to mate the two ends. I can see the pedal to floor mounts need some welding to fix rot-out. "Am I smarter then a 5 year old" Don't answer that Zig!! Flashlight
Drum or driveline? Flashlight - please clarify which type e-brake you have. The Shop Manual describes both.
Thanks Larry, I have the pedal type, looks like I need a clevis to the pedal. I am not sure how the spring, draft seal and a leather piece go together, in what sequence. Is the spring under the pedal release bar? Flashlight
Thanks, I have a 47 Shop manual, it helps with most everything....as you know the floor lever was changed to pedal type in 48'. The pics wouldn't come up. Appreciate your imput. Flashlight
