Emergency Flashers and Ignition switch
Discussion in '1955-1959' started by steve, May 8, 2010.
  1. steve
    steve Member
    Virginia
    Hello,
    Two separate questions but electrical related...
    Has anybody installed emergency flashers to their stock truck without installing the aftermarket turn single switch that mounts on the colunm? But using the existing turn switch?
    I already have the brown wire from a aftermarket fuse box, (must be power?)
    Second any good aftermarket ignition switched out there? mine I can remove the key in any position and cant tell what position it is in, bad for the electrical choke.
