engine missing
Discussion in '1973-1987' started by cediver, Jan 14, 2006.
  1. cediver
    cediver Member
    I got a 290h.p./350 Crate. I have everything new on it with the exception of an alternator which works just fine. I have an Rpm Air Gap manifold with a 600cfm performer carb, a stock HEI Gm distributor with a Hypertech cap, coil, and rotor, with Accel superstock wires. My problem is a miss, noticeable at idle. I'm some what of a perfectionist and this is just killing me. The distributor, on the inside seems loose to me, but that's the only other thing I can think it might be. Possibly the ignition shorting out or jumping spark in the cap. I could see black marks on the underside of the rotor, possibly pointing to that. I have it timed and everything, I just can't get rid of this damn miss, and it's driving me nuts.
    Any help, and I mean any would be great. I'm thinking of popping the valve covers to check the valve adjustment, but I'll wait to hear back from somebody first.
    Thanks,
    Casey
  2. 81 BLAZER
    81 BLAZER Member
    First thing I would do is check plugs!! cheap and it is hard to tell if you are just getting a weak spark from one of them... does it only do it at an idle or also when you start to accelerate?
