engine number
Discussion in '1947-1954' started by 47chevyrod, Apr 10, 2007.
  1. 47chevyrod
    47chevyrod Member
    Slaton tx
    I have a motor that I am intending to put in my 47 if my 216 is cracked. The number off the side is 3833057. we think it is a 250. I would like to know what year it is and anything else anyone knows about the engine. thanks
  2. Kens 50 PU
    My reference material is not that "new" but what i can gather from a google search is that casting #3833057 is an inline 6-cyl produced between '62-70 with a cubic inch displacement of 194 cu. in.
  3. 47chevyrod
    47chevyrod Member
    Slaton tx
    thanks. I guess a 194 will do It wasnt what I was hoping for but it will work.
  4. Kens 50 PU
    Bore it out to a 230...
    and it will run for 250,000 miles! The one in my '63 biscayne did! Replaced a water pump at 130K, but that was it!
  5. 47chevyrod
    47chevyrod Member
    Slaton tx
    This one runs great but will it pull my truck ok and have as much power as the old 216
  6. Kens 50 PU
    Sure it will. Let me give you the credentials. 216 (based on the 50 model) GHP 90@3300 rpm, NHP 83@3200 rpm, gross torque 174 ft-lbs@12-2000 rpm, net torque 168 ft-lbs@1100 rpm.
    194 GHP 120@4400 rpm, NHP 95@4000 rpm, gross torque 177@2400 rpm, net torque 165@2000 rpm.
  7. Kevin's 48
    Kevin's 48 Member
    Tn
    Where do you find this stuff Ken? You seem to have all the books with all the technical need to know things in it.
  8. 47chevyrod
    47chevyrod Member
    Slaton tx
    so the 194 has a little more power than the 216 that makes me feel better. Is there an intake out there so I can put dual carbs on it and maybe split exhaust. Also I need a carb for it I used my 216 carb to run it in the stand but the bolds on the 194 were farther apart so I had to use an adapter that turns the carb 1/4 so if I do put it in my truck the linkage wont hook up. what carb will work?
  9. Kens 50 PU
    two people!
    My grandfather and my father. I have read and almost memorized every book, manual, tech bulletin, you name it, that both of them ever owned. They are the fondest memories I have of both of them!
  10. vwnate1
    Not To Pi$$ On Your Parade But
    The 194 C.I. 6 Banger was introduced in 1962 and was GM's very 1st. thinwall casting engine ~ they're O.K. engines , I prefer the 230 or 250 version as the 194 is pretty gutless . many suffered from flat cams just like 350 V-ates did . these engine do _NOT_ suffer dirty oil well so keep it changed regularly...
    I like the Rochester B1BC Monoblock carby they come with new , in auto choke or manual choke versions they carburet very well and have no flat spots on cold mornings etc....
    I had several Chevy II's and Novas plus a Biscayne or two that had this engine , I felt all of them to be underpowered .
    Me , I'd go find a cheap or free 235 takeout and use that , more useable power and a straight bolt in deal too .
  11. Kens 50 PU
    Refresh my memory
    Did the 194 have an integral intake/exhaust manifold? For that matter, did the 230?
