davidrw
Hi Guys
I'm doing an oil change for the first time on my 1965 C10 230ci straight 6. Now the owners manual specifies 10W30 oil, however here in the UK it is difficult to get hold of. Do you know what other grade of oil i could use? I will be doing approx 2000 miles per year.
Also changing the diffential cover gasket, same as above what modern grade of oil can be used here?
Thank you your guidance will be appreciated this side of the pond!!
