Factory Assembly Manual Bolt/Screw Numbers?
Discussion in '1947-1954' started by mockoski, Mar 27, 2017.
  1. mockoski
    mockoski Member
    Good evening,
    Wondering if any one has come across a chart that shows the bolt/Screw numbers listed in the 1947-54 Chevy Truck Factory Assembly Manual "Fam", and the actual size of this hardware?
    Trying to locate the Steering Gear Assy bolts to frame ( Bolt no. from "Fam" 103329, 106297).
    Also the Grill/Radiator Baffle and Fender Brace Bolts/Screws
    120834 , 365059
    120228, 122007
    Might anyone have the code book that explains what the size of this hardware actually is?
    Thanks,
    James
  2. Bill Hanlon
    I checked the GMC Parts Book Light Duty Models 100 thru 370 (1939-50) Models 100-22 thru F350-24 (1951-53) and the 1960 GMC Master Parts Book (covers 55.2 thru 60) which both have a numerical cross reference index and a section on "standard parts" (nuts, bolts, cotter pins, tubing fittings, etc.) Unfortunately, no hits on any of your numbers. I don't know if the Chevy truck parts book has a similar cross reference. I also checked the earlier GMC Parts Book for attaching hardware in section 16.0290 Steering Gear Housing, but none were listed.
  3. mockoski
    mockoski Member
    Thanks Bill..
