finally a set of headers that fit
Discussion in '1960-1966' started by cowboy, Sep 20, 2004.
  1. cowboy
    cowboy Member
    hello ya'll just sayin hi. i finally got a set of headers to fit my 454 in my 62 3/4 ton 4x4. i ordered a set of sanderson street rod headers. They did need a little notching on the frame. going to get my ehxaust hooked up tomarrow. get my flowmasters hooked up again. took 4 different sets of headers to find one set that both headers fit.
    Cowboy
  2. chevy65cvy
    chevy65cvy Member
    dundee usa
    lift for a 65 4x4
    sounds like you have a 4x4, did you put a lift on it. if so how did you do it. i have been loking all over for someone that makes lift springs for a 60's series 4x4
    any info would help!
  3. cowboy
    cowboy Member
    RE: lift for a 65 4x4
    I didn't put a lift on my pick up. i have stock suspension. i believe i can clear 35's no problem. i have abuddy witrh a set of 35/15/16.5's that i and going to see if it will clear those for height. I'm probably going to run a 34x9x16 on my pick up. For a lift upi can shackle lift the front.the rear springs are 2.5" wide not sure but i think they area 56" long so if you can get some add a leafs orsring pack that meets those requirementsthern you are set. i'd like to get a couple more inches of lift but these old pick ups aren't going to be to tought to lift.
    cowboy
  4. chevy65cvy
    chevy65cvy Member
    dundee usa
    My truck still has the same tires that were on it when i bought it, and they are 36"s, tthe only problem, i have noticed, is that when you turn hard right, the front drivers side tire, looks like it rubs on the steering knuckle.
