Firewall
Discussion in '1947-1954' started by bigmikes50chevy, Dec 29, 2010.
  1. bigmikes50chevy
    bigmikes50chevy Member
    Fresno
    Hello All,
    Happy Holidays! What size are the two holes in the firewall that the speedometer, temp sender, oil pressure line, choke and throttle cable pass through (1950 3100)? I have a smooth firewall and I need to drill both holes.
    Thanks in advance,
    Mike
  2. Kens 50 PU
    Damn good question!
    I don't know the answer because mine was pre-drilled at the factory!
    What I would do is buy both grommets and take the inside measurement inside the groove and drill the holes accordingly.
    Something to think about.
    Ken
  3. ol' chebby
    Just barely big enough for the grommets to go through.
  4. jackson
    jackson Member
    Gold Bar, Wa.
    The one closest to the center of the firewall is 1 1/8" dia., and the speedo hole is 1 1/6" dia. My firewall is stripped down w/o grommets so I had easy access to measure them.
  5. bigmikes50chevy
    Fresno
    Thank You! The grommets are on order otherwise I would have just measured the grommet itself. Be safe this New Year!
    Mike
  6. Haasman
    Haasman Member
    N. CA, south of SF
  7. bigmikes50chevy
    Fresno
    Thank You!
