Hey gang, I have the classic parts turnsignal, and just got the 6-volt flasher that I apparently need. Two questions. How are most of you folks attaching that flasher to the inside of the dash -- what kind of clamp and where could I get it. Also, do I need some special kind of connecter to hook the wires from the turn signal into the 3 prong flasher? any thoughts on any of this would be much appreciated! Thanks in advance! Eric
Flasher I just use a plactic zip tie and strapped it to the wire harnes at a thick point. No special 3 prong connector that I know of; each wire just gets hooked up indiviually with a standard flat connector. You may be able to find a 3 prong connector at your local autoparts store but not sure it is worth the hassle.
3 Prong Flasher Socket Use an headlight connector , they're available in the " HELP ! " section of most FLAPS or off most any old junker... To hold the flasher can to the dash , there's supposed to be a cute little backet provided with each and every IDEAL brand flasher , I dunno if they still do that , it'll hold the flasher vertical or horizontal , attaches by one single screw ~ I use zip ties these days .
