Fliping the cab
Discussion in '1955-1959' started by HOT RODDER 1932, Jan 26, 2008.
  1. HOT RODDER 1932
    HOT RODDER 1932 Member
    Oregon
    I need to lay my cab on it's back to sandblast the under side of it. I have a fork lift and a gantry to do the lifting. What is the best way to lay it on its back and is the structure strong enough to not cave in?
  2. rxpx40
    rxpx40 Member
    Buda, Tx
    If your cab is completely empty, you should have no trouble laying it back on the rear surface. If I recall correctly, when I sandblasted my cab, I rolled it back myself. At most you will need one other person to help you. I did mine in the yard, no damage to the sheet metal.
    Chris
  3. steve
    steve Member
    Virginia
    Cab Removal
    I used a lift and 2x6 through the cab where the door would be. No problem lifting. I also laid my on it’s back on a flat surface and on foam pads. No problem. I then primed and painted the bottom at that time. :)
