Floor seal
Discussion in '1960-1966' started by LittleStar, May 13, 2009.
  1. LittleStar
    LittleStar Member
    SOCAL
    Anyone know of a source for a gasket or seal for the removable trans cover in the floorboard? You know the one with the hole in it for the 4 speed toploader gearbox. I've looked through everyone's catalog with no luck. Thanks......
  2. fixie
    fixie Member
    Swartz creek Mi.
    As far as i know the best way to seal the hump is with 3M strip caulk. put two strips all the way around and bolt hump back on if you have the shifter to hump foam seal put that on first it seals out the junk from the top of the shift tower.
  3. LittleStar
    LittleStar Member
    SOCAL
    Thanks........I blanked the shifter hole off account of I don't need it. I just need to seal the cover to floor seam.
